Zum Hauptinhalt wechseln
iON SnapCam 1046 Lite Battery Replacement
Was du brauchst
  1. iON SnapCam 1046 Lite Battery Replacement, Camera Lens and Cover: Schritt 1, Bild 1 von 2 iON SnapCam 1046 Lite Battery Replacement, Camera Lens and Cover: Schritt 1, Bild 2 von 2
    • Remove any external skins placed on the device. To do so, simply lift up and peel to remove.
  2. iON SnapCam 1046 Lite Battery Replacement: Schritt 2, Bild 1 von 1
    • Firmly pull on the back clip in order to remove.
  3. iON SnapCam 1046 Lite Battery Replacement: Schritt 3, Bild 1 von 1
    • Use a Phillips head screwdriver to remove the four 4mm PH00 screws located on the sides of the device. All screws are located under each of the grey covers for the microSD card and the microUSB insert.
  4. iON SnapCam 1046 Lite Battery Replacement: Schritt 4, Bild 1 von 3 iON SnapCam 1046 Lite Battery Replacement: Schritt 4, Bild 2 von 3 iON SnapCam 1046 Lite Battery Replacement: Schritt 4, Bild 3 von 3
    • Grab a metal or plastic opening tool and insert it into the middle slot on the bottom of the camera and lightly pry open.
    • Locate the camera lens in the bottom left-hand corner of the picture which can be replaced by replacing the entire cover. The back of the cover is also shown. The camera is now located in the top right-hand corner of the picture.
  5. iON SnapCam 1046 Lite Battery Replacement, Battery: Schritt 5, Bild 1 von 2 iON SnapCam 1046 Lite Battery Replacement, Battery: Schritt 5, Bild 2 von 2
    • Use a nylon spudger to gently pry the four tabs holding the motherboard in place.
  6. iON SnapCam 1046 Lite Battery Replacement: Schritt 6, Bild 1 von 2 iON SnapCam 1046 Lite Battery Replacement: Schritt 6, Bild 2 von 2
    • Lift the motherboard to reveal the battery compartment. Remove the thermal tape holding it in place and replace battery.
    • WARNING: Lithium Battery!
Abschluss
IUPUI, Team S22-G4, Bayer Fall 2017 Mitglied von IUPUI, Team S22-G4, Bayer Fall 2017
IUPUI-BAYER-F17S22G4
5 Mitglieder
4 Anleitungen geschrieben
2 Kommentare
Can you please list the battery specifications for selecting the correct replacement battery?
Thank you for the posting and assistance.
james - Antwort
Where can I find a replacement battery?
Issis - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 15
Insgesamt: 517
