Zum Hauptinhalt wechseln
Der PowerMac G5 ist ein Desktop-Computer, der erstmals 2003 von Apple Corporation produziert wurde. Diese Anleitung zeigt dir, wie du den PowerMac G5 (Modellnummer A1047, EMC: 2061, von 2004) reparieren kannst.
197 Fragen Alle anzeigen
Can't boot up power mac g5
I have power mac g5 (2003), it is 2.0GHZ dual processor and running 10.5.8, some time boot up, but some time can't boot up. I try use the Install CD/DVD that came with my system to boot up , I got same result some time it boot up, some time can't boot up. please help me and let me know why?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
There are diagnostic lights on the logic board please take a look at them and tell us what they are showing.
Location Name Color Status Indicates
LED 1 Yellow On Yes Power supply is providing trickle power
LED 2 Red Off No CPU B halts on an IERR (instruction error)
LED 3 Red Off No CPU A halts on an IERR (instruction error)
LED 4 Red Off No CPU B is over temperature
LED 5 Red Off No CPU A is over temperature
LED 6 Green On Yes EFI has configured the graphics card
LED 7 Power on Green On Yes All power rails are functioning
LED 8 EFI done Green On Yes EFI is done loading GPU present
CPU A (lower
processor)
Overtemp
CPU B (lower
processor)
Overtemp
CPU A (upper
processor)
Error
CPU B (lower
processor)
Error
Trickle
power
LED Button
to Display
436 Troubleshooting a Mac Pro
War diese Antwort hilfreich?
Bewertung 2
4 Kommentare:
my g5 don't have diagnostic lights on the logic board.
von
Diagnostic LEDs
The Mac Pro logic board includes a set of LEDs to help service providers
troubleshoot the computer. The LEDs are located toward the rear of the logic
board, under the memory cage, next to PCI card slot 1. You can view these
LEDs by removing the computer’s side access panel and looking through the
memory cage to the logic board below. Diagnostic LEDs location on the logic board, numbered 1–8 from left to right
LEDs 2, 3, 4, and 5 are normally off and will illuminate automatically if an
error occurs. To read LEDs 1, 6, 7, and 8, you must press the DIAG_LED
button, which is adjacent to the LEDs. To press the DIAG_LED button, use
the nylon probe tool.
NOTE There is a position on the logic board next to LED 1 for a SLEEP
LED that does not have any LED installed. This is normal; the LED was
used only in development. To determine if a Mac Pro computer is in sleep
mode, watch the power LED on the front of the computer. It will slowly
change brightness levels if the computer is sleeping.
von
I didnt see any LEDs other then the power light, does the 2003 model have them on the board?
von
You can resolve many system problems by resetting the logic board.
There are three reset switches on the logic board that you can use to troubleshoot
various issues:
SMC reset: If the computer is experiencing a power issue, resetting the
system management controller (SMC) may resolve it.
RTC reset: If the computer is experiencing a booting issue, resetting the
Real Time Clock (RTC) may resolve it.
System reset: You can use this switch to determine if a computer that
won’t consistently boot from a cold start has power supply issues.
von
I’m having the same issues on my A1186, it says “ERRA” on the mother diagnostic but doesn’t post, I tried taking out the clock battery and placing it back in and I’ve hit the reset button ontop of replacing both the processors. Am I missing something or do I need to install the OS for it to boot?
Bewertung 0
Antwort hinzufügen
larry lin wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 13
Insgesamt: 2,310
