Zum Hauptinhalt wechseln
2001 Buick La Sabre Limited's RPM gauge drops to zero while driving?
My Buick's rpm gauge goes from working just fine to 0 in a matter of 20min. The car jolts a little bit when this happens and used to turn off completely while waiting at a red light/stop sign/idling. Can someone help me figure out whats going on?
Ive replaced the following:
Spark plugs/wires, fuel filter, serpentine belt, MAP sensor, Battery (brand new and 200$), gasket seals, oil change.
Thanks!
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar
A faulty crank sensor can cause rpm issues along with poor running conditions!
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
When it "goes to 0," does the engine shut off, or does the car mysteriously recover and keep on working? Could it be a faulty ignition switch?
My Accord used to just randomly turn off while in the middle of driving, and it took me a couple of months to figure out my ignition switch was bad. I replaced the ignition switch and things worked perfectly since!
War diese Antwort hilfreich?
Bewertung 3
Can someone tell me why my 2000 Buick LeSabre speedometer not working RPM and Signal lights
Bewertung 0
1 Kommentar:
Did you get the problem fixed
von
Antwort hinzufügen
tarah wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 26
Insgesamt: 2,772
