Zum Hauptinhalt wechseln
16-Bit-Videospielkonsole des japanischen Unternehmens Sega, die 1990 in Europa veröffentlicht wurde.
37 Fragen Alle anzeigen
Why can't any controller plugged in as the first controller press up?
So I can use up on all my controllers in the 2nd controller slot so I know the controllers are fine. But whatever controller is in the first slot doesn't allow me to press up. I'm guessing there's something wrong with the connectors so I'm just wondering if I should just replace the whole thing or if there's an individual pin I could fix.
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
1 Antwort
I am not an expert on controller ports but if it is not letting you do certain tasks with your controller, it could be dirty. Try cleaning it with Alcohol and Q-tips/ paper towels. I would also recommend using a nylon brush (a toothbrush can work in a pinch if it is clean). Finally, when you finish scrubbing it down, use compressed air to blow any remaining debris out.
If cleaning it this way doesn’t work, then a deeper cleaning involving more tools such as picks from the cleaning section on ifixit may help. You can use those to force whatever is in there, out. But do this as a second last resort.
Worst case scenario, you’ll have to order a replacement part and sell the broken one online for parts. That way you can still decrease ewaste while fixing the issue.
Hope this helps!
  • Jakes Restorations
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Josh Lowe wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 3
Insgesamt: 217
