Mitsubishi tv won't come on
Green power light comes on ,goes off, no pic ever comes on
Ist dies eine gute Frage?
Judy Bush, check all the pico fuses on the board. There should be either 4 or 6. Check for continuity. Most likely that two are shorted out. This model has issues with the Convergence Correction Circuit IC STK393-110. Now it is up to you and your skills. Always make sure that you unplug your TV and leave it unplugged while you work on it. The caps will hold power for quite a while and you would not want to get zapped. You will need a multimeter and a few other tools to try and fix your set.
War diese Antwort hilfreich?
I have no picture..but full sound??
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 9
Insgesamt: 1,192
Green light comes on and go's off
von richardstricklin2020
