Zum Hauptinhalt wechseln
The Toshiba Satellite M45 Laptop is designed for powerful, portable, multimedia computing. It features a 15.4” WXGA Display running Microsoft Windows XP, with 1.6GHz Processor, 512MB RAM, and 80GB Hard Drive.
13 Fragen Alle anzeigen
How to verify connection of USB ports & S-Video port to motherboard?
Is it possible to open only the rear panel of this laptop model S269 and check the motherboard connections to S-Video port and the 2 USB ports above the DVD drive?
I had tried to open the rear panel and when failed to do, fixed it back but since then, the ports mentioned above are not working.
Your suggestions would be greatly appreciated.
Thanks,
Rupesh
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
according to the board layout on page 226 the usb and the s-video connector are in the same area of the motherboard - so most likely you disconnected (or broke) something in that area
the connection shoul be on the back- or bottom side of the motherboard
the service manual can be found here: CLICK
you can also use this service manual to correctly disassemble the notebook
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Rupesh wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 5
Insgesamt: 586
