My headphones don't work when I plug it into the jack?
My headphones work fine when I'm using them on my phone but for some reason they don't work when I plug it into my computer. How do I fix this?
Ist dies eine gute Frage?
Alyssa Kristedja. Make sure that the drivers for your audio card are properly installed. Also, and I know this sounds stupid, but make sure that your headphones are properly plugged in to the headphone jack, not the mic etc. If that still won't work, check the bios to make sure that your audio card is properly initialized.
War diese Antwort hilfreich?
bruh bruh im still 9
And im just 10 but what do u mean by not the mic
and I'm HeadPhones do work but we plugging in the sound. won't work to the headphones.
Assuming your headphones do in fact work, it might be that the device isn't recognizing them or just overrides them. If this is the case then you can manually connect and set your headphones as default through these steps..
For Windows 8 and 10 move your mouse to the top right of your screen and then straight down to bring up the charms sidebar.
a. Click settings
b. Click Control Panel.
c. Go to Hardware and Sound.
d. Click on Sound.
e. Right click your headphones in the pop-up window
f. Click connect
Hopefully this will set your headphones as the primary playback device. If this fails see the troubleshooting page mentioned above.
What if you dont see your headphones in that window???
i dont see the word connect as on option, so i just clicked ok but it still didn't work.
bro thank you so much
I was having so much trouble trying to figure out what happened
so this really saved me
FOR MACBOOK AIR-
Im so happy that i figured this out
It might not be 100% accurate
1) Go to settings
2) Click Sound
3) Click output
4)plug your earbuds in
5) Click headphone port
6) slide the balance bar around, and it should work
(if you take your headphones out and it doesn’t make noise, slide the bar around again)
Hope this helped
This also works for Microsoft. Instead of clicking on sound, type in the search bar "sound" and click on the tab that says sound settings.
I have the same problem, everytime I plug in my headphones it says they aren’t plugged in, and these are brand new. Although, I tried restarting my Dell and now my headphones are working. I’m assuming you have to restart your computer every time you plug in your headphones to work, hopefully this works for you guys too
yeah but how do i make it so i never have ti restart
I'm having the same problem. I have a Dell laptop and so I've been taking with the reps. They gave me links to reinstall and I'm still having the same problem. The install links I got were: chip set, bios and the audio driver. I tried different headphones with no luck. I've looked online for a fix. One actually worked but it was only temporary. I'm wondering if my bluetooth devices are part of the problem even though they were never an issue before. I've never had this problem before and this one is a complete mystery. Even the reps at Dell are stumped. Their solution is to do a mail-in service.
On one phone, it didn’t work until I pushed hard on the plug and heard a click.
An answer that worked for me.
Go to Device Manager
Double Click on Sound, Video, and Game Controllers
In the dropdown menu, click on a device starting with Realtek.
Right click the device and click Uninstall.
This will trigger you to reboot your computer.
Click on OK.
While your PC is booting back up, plug in your headphones immediately.
After restarting, they should work.
Thank You very much Joshua I was trying to figure out for a half an hour why when I plugged in my headphones I was receiving no sound? This was after I used a wired mic in the same port.
Letzte 24 Stunden: 5
Letzte 7 Tage: 46
Letzte 30 Tage: 269
Insgesamt: 150,180
5 Kommentare
i have the same problem too and i dont no what to do
von Allen McKee
I plugged the headphones into my computer and then restarted it. They worked after that.
von David Gray
im trying to do a meeting and i cant hear whats happening
and when im doing code.org for fun the music aint working
von Allegra
my work headphone doesn’t work when i plugged in
von Dyno_Poter
IMPORTANT: YOU GOTTA REMOVE REALTEK AUDIO DRIVER AND ENABLE WAVES DRIVER (I use dell laptop and it fixed the problem)
von 1 godzinę
