Zum Hauptinhalt wechseln
First released in January of 2014, the Pebble Steel is a steel-bodied Smartwatch from Pebble Technology Corporation.
7 Fragen Alle anzeigen
My Pebble steel isn't vibrating when I receive a new notification
My Pebble Steel watch is not vibrating when I receive a new notification. I can still see when I get a notification because it pops up on the screen but I don't feel the vibration. I have made sure that the settings on my phone and watch are both set to vibrate for a new notification. What else can I do?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 4
1 Kommentar
that fixed the problem. thanx.
von
Einen Kommentar hinzufügen
6 Antworten
Gewählte Lösung
Also, try visiting the troubleshooting page for more help.
War diese Antwort hilfreich?
Bewertung 6
Hilfreichste Antwort
Mine was in Quiet Mode. You can change this in the settings. You can also change this by holding down the button on the left side of the watch while at the watch face.
Bewertung 18
12 Kommentare:
Worked for me, i feel so stupid now
von
Mine was not working either, Supid #2! Thanks!!!
von
Wow! Thanks! *face palm*
von
Add me to the dummy list! Thanks for the help
von
Not working. Howwwee
von
7 weitere Kommentare anzeigen
Try resetting the watch.
Bewertung 3
3 Kommentare:
I reset it and it only vibrates on phone calls.
von
I reset mine nothing, no vibrating at all. I'll try again.
von
Though it works, feels over kill. Try the quiet mode
von
No solution worked. No vibration at all even after hard reset
Bewertung 1
My pebble steel started to vibrate again, after android wear app was removed
Bewertung 0
2 Kommentare:
I had same problem after installing Android Wear. I took 'belt and braces' approach and deleted AW app and also did a factory reset on the watch and signed in with a new account to make sure I really was back to 'factory settings'. I chose this boots-and-all approach as I had previously also installed a new watchface (Beacon) which screwed the watrch up completely and caused it to reboot at random times and I wanted to make sure I had totally got rid of it.
von
Thanks. I m on the top of the dummy list!!
von
Just discovered this:
Notifications will appear, but not vibrate, when the Pebble Time is charging.
Bewertung 0
Antwort hinzufügen
Orlandria Heggs wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 13
Insgesamt: 15,624
