Zum Hauptinhalt wechseln
The Toshiba Satellite L300 was a notebook designed and sold by Toshiba that came with a version of Windows Vista. They were sold around May-June 2009 and while ineligible for the free 7 upgrade, time past and upgrades are unclaimable now, run 7 home premium well without upgrades mainly because of Vista's resource hog quality. Also known as Toshiba Satellite L300-04P (PSLB8C-04P01X).
30 Fragen Alle anzeigen
How to repair a USB port that won't accept a USB device?
I tried to plug in a USB cacble to my Toshiba Laptop and it would not go into the purt completely. The connection was not complete as the device I was trying to plug into the Laptop USB port would not work. I am not sure if the problem is with the Laptop or the USB connector on the device I was trying to plug in. How can I identify the correct point of failure? Would it be on the computer USB port or the usb device I am trying to plug in.
Once this is determined, how can I repair the USB connection, or does this require parts replacement?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
droyhull sounds like a mechanical issue with the port since you cannot properly insert a USB cable/device. In that case you will have to solder a replacement USB port unto the motherboard.
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
droyhull wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 10
Insgesamt: 148
