Zum Hauptinhalt wechseln
Model number MFC270EN was released in 2012 and uses Android 4.0.
3 Fragen Alle anzeigen
My LexiBook Junior tablet won't turn on
My Lexibook Junior tablet is over 3 years old and I've had it plugged in for a really long time, but it won't turn on. The charging cord looks fine and I haven't abused it, so why won't it power on?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Check if the charging port in the tablet is damaged or if the charger will not fit into the charging port. Check for corrosion on battery. Depending on how old the battery, it might be bad and need replacing. Look for damaged wires within internal circuitry. Also, Corrosion on motherboard may lead to your tablet failing to turn on. In this case, return it to the vendor. For more information check out the troubleshooting page.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Rachel Klesius wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 18
Insgesamt: 841
