alarm system going so car won't sart
The rear window has blown so when I try to start the car the alarm horn goes and the flashers go off and car won't start
Ist dies eine gute Frage?
Hi, it's perfectly normal, the security alarm system (after market or OEM) works preventing the fuel pump to operate while it it is engaged.
In order to start your car you have to first turn your alarm off. You could try:
1. unlocking your car and being 100% sure the alarm is disarmed whit the control. (If it's OEM there are some system to disarm the alarm open the driver door whit the key.
2. Searching on the fusile compartment, under the dash on the left side of the car, for any relay or fusile labeled like alarm or something like that. Just take it off. But this only work in OEM alarm systems.
3. in case you are still in trouble or the alarm system it's after market sometimes works unplugging the whole thing. You would have to find it first, normally is under the dash, on the driver side, look for a small plastic box with severals plugs & cables, labeled with a security system mark or just with out any label.
Best of lucks.
War diese Antwort hilfreich?
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 22
Insgesamt: 236
