Massey Ferguson tractor won't start
My tractor won't stay running without easy start, it ran low on fuel have tried to get air out but still won't run, it will turn over but that's it, can anyone help me please.
Ist dies eine gute Frage?
@holly1catherine ,Catherine, Ensure battery is fully charged. Trouble bleeding air out, just barely crack open each fuel line (one at a time) right at the injector while someone cranks the engine over. As soon as you get fuel coming out tighten it back up again. If no fuel could be plugged filter, clogged/damaged/pinched fuel line, faulty pump. The link below has a really thorough write up on bleeding/trouble shooting diesel fuel system approx 1/2 way down the page. Good luck.
War diese Antwort hilfreich?
hello, i had the same problem with my 1100 massey ferguson. was down and i went thru the entire fuel system. but when i was trying to crank it, the engine did the same thing. it was down for three years with no luck running. i finaly was going thru everything and thats when i removed both filters and noticed that one of my wix filters did't have holes on top like the other one. so just to be sure, i purchased two new filters of a didderent brand and both had holes on the top and after bleeding the system, the engine cranked. check your filters and goodluck.
check our neual safty switch ires mine was loose
You are welcome you have a salty switch under the seat
Sorry about spelling that is saftety
I have a Ferguson t20 tractor I put a new carburetor on it I have crank no start I put a new fuel on, had starting fluid sprayed in carburetor starter right up two seconds turned off what am I doing wrong.
( JOHN P )
Troubleshooting a Massey Ferguson Tractor That Won't Stay Running:
**1. Check Fuel System:
**2. Inspect the Air System:
**3. Verify Fuel Quality:
**4. Inspect Glow Plugs (If Equipped):
**5. Check for Fuel Injector Issues:
**6. Examine the Battery:
**7. Verify Fuel Pump Operation:
**8. Inspect the Ignition System:
**9. Examine the Exhaust System:
**10. Consult the Manual: - Refer to the tractor's manual for specific troubleshooting steps and maintenance recommendations.
If, after going through these steps, the issue persists, it may be advisable to seek assistance from a professional mechanic or Massey Ferguson dealership for a more in-depth diagnosis and repair.
@jerryrodan AI generated answers need to be flagged/marked as such. You are responsible for the content of the AI regurgitated technobabble answer.
Letzte 24 Stunden: 14
Letzte 7 Tage: 115
Letzte 30 Tage: 493
Insgesamt: 33,144
7 Kommentare
my MF 202 will not start It stalled . I turn the key on push start button nothing happens
von johnrdv
Having trouble starting a Massey Ferguson tractor? Frequently ask a question on Google by Farmers. Make sure the battery is fully charged. If you are having trouble bleeding out air, just barely open each fuel line (one at a time) while someone cranks the engine. Once fuel starts coming out, tighten it up again. https://www.tractorcorner.com/jm/
von tractorcorner
I got a 1977 Massey Ferguson tractor charge the battery up ram shut it off won't start what do I do
von richardbevmyers
What do I do to get it started
von richardbevmyers
I charge the battery till it gets full and it starts then after I shut it off it won't start again what do I do
von richardbevmyers
2 weitere Kommentare anzeigen
