Zum Hauptinhalt wechseln
Manufactured from 2004 to 2009, the Vino 125 has a 125cc engine.
22 Fragen Alle anzeigen
Vino won't start when it's cold
My 2007 Vino is a cold starter. I try to start it and just turns over and over. Whether I give it throttle or not. I leave it for a while, go back and it will start. Then it starts fine rest of the day. I sometimes go weeks without starting it.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
@partyponies , Rebecca , If you are getting a spark and fuel to the carburetor and the engine cranking over on good, the problem is probably the electric choke or heating element for easy cold start is not operating correctly. When the engine is cold the choke is required to start engine correctly, If faulty, the mixture will be weak and the engine will not want to start easily. Have a good local shop check it out, diagnose and estimate repair.Links below may be of some help, 1st link is about troubleshooting and the 2nd link is a service repair manual not your exact year but may work. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
http://www.scooterfocus.com/scooter_trou...
http://www.49ccscoot.com/manuals/Yamaha_...
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
I can't get gas to the carburator. Whatis the possible problem
von
I found help on U-Tube. Turn the throttle 5 times before starting. It worked like a charm. Doesn't fix the problem, but it starts. Your answer is probably right, electric choke or heating element may need some attention. Thanks for giving me an answer.
Bewertung 0
1 Kommentar:
I can.t get fuel to the carburater. that is the main problem
von
Antwort hinzufügen
Rebecca wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 17
Letzte 30 Tage: 65
Insgesamt: 5,350
