Zum Hauptinhalt wechseln
The third generation Kia Rio debuted on March 1, 2011, at the Geneva Motor Show, again based on the Hyundai Accent.
11 Fragen Alle anzeigen
Vehicle won't crank over
Vehicle won't crank over. I've replaced the crankshaft sensor, checked the alternator, battery, starter, coil packs, and replaced the spark plugs. And replaced the fuel pump. Just won't crank over. Any suggestions
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 3
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
If you have a no crank situation and you have a good starter for sure then look for possible wiring issues . Look closely at the grounds. Check for engine codes as well . When you attempt to crank the car do you loose power to lights check the voltage at the battery as you attempt to crank . If you loose all voltage it could be a week cell in the battery that only shows up under draw conditions . Hope this helps
War diese Antwort hilfreich?
Bewertung 4
1 Kommentar:
Did you find out what was wrong? Im having the same issue with a Kia Rio 2011
von
Antwort hinzufügen
Royce J Daniels wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 17
Letzte 30 Tage: 67
Insgesamt: 4,912
