Zum Hauptinhalt wechseln
Released Quarter 2, 2014. Identifiable by Model Number: HBS-750.
11 Fragen Alle anzeigen
Why can't I hear the music on both side of my earphones?
I had this pair of earphone since Christmas and has been working fine, but all of a sudden I cant hear the music, I checked everything on the device the Bluetooth still connects to my phone and charges well, but I have to move the wires around and you can hear a faint sound but has to be in a certain position, I was told to open up the earpiece but I have no way too open, need help!!!!!
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
Please how I fix the problem of not hearing my callers but they hear me? Please i need urgent answers. Thanks
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Typically, when you have to move the wires around to hear the sound. It means there is a bad wire connection between the speaker and the amplifier in the earphones. There is pretty much only two ways to fix this problem. The first is to tear down the earphones and try to manually reconnect or adjust the connection. The second is to just end up buying another pair.
Best Regards,
Drew
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
I see, but the problem is there is no way to opening the earpiece and even tried using a razor to cut my own way in. but yet no luck, any recommendation??
von
This guide I attached below may be of help to open the earpiece. It is not my guide and I have not ever used these earphones, but I am trying to help based off previous knowledge and experience.
Best of Luck,
Drew
LG Tone Pro HBS750 Magnet Replacement
von
Antwort hinzufügen
LelandAnagal wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 18
Insgesamt: 1,346
