Zum Hauptinhalt wechseln
Freezer doesn't work properly. Not cold enough
My samsung upright refrigerator has the freezer in the bottom. It stopped working but the fridge part is working well. Actually the freezer becomes a fridge. Don't know why. We unplugged and kept it off for 24 hours, but problem still there. However, if we "power freeze", the freezer will work until we turn off "power freeze" button.
Not sure what to do by myself. Do I need to buy a new one?
Ist dies eine gute Frage?
Bewertung 3
4 Kommentare
Please give us a model number. Usually the freezer is used to cool the fridge.
von
It’s Samsung RB196ACBP. And 7 years old.
von
I have the same probleme inmy freezer
Beko RDNE500K21W
von
freezer not cool not snow freez only working
von
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
The most common cause for this condition is a problem with the defrost system.
I would replace the defrost thermostat: https://www.repairclinic.com/PartDetail/...
War diese Antwort hilfreich?
Bewertung 2
8 Kommentare:
Thank you. I will try to replace it by myself. Don’t know how to start. First locate the thermostat, then buy the part and replace it.
von
is the right part in your link that I need to buy? Normally where is the thermostat? Thank you very much
von
yes. that the correct part for your model. As to where it is, I think my link has a 2 min video of how to install it.
Yep, here it is: https://www.repairclinic.com/Video/Video...
von
Thank yo mayer. I will give it a try
von
HI Mayer, Just want to know, is this part you mentioned for my Samsung fridge. Should it be defrost thermostat DA47-00243K? my fridge isSamsung RB196ACBP
von
3 weitere Kommentare anzeigen
Take a look at this article:
https://www.networx.com/article/why-is-m...
Bewertung 0
This problem recurs in my fridge/freezer and I resolve it by taking out the inner panel of the freezer compartment to expose the freezer unit at the back of the freezer. This unit ices up occasionally and becomes a solid block of ice, the result of which is to severely impair the function of the freezer. Defrost until there is no sign of ice between the freezer pipes and fins etc, replace the cover and switch on. In my case with a Beko freezer, this does the trick and it works like new after defrosting.
Bewertung 0
1 Kommentar:
Thank you. i will try to melt the ice and replace the cover.
von
Antwort hinzufügen
Min wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 16
Insgesamt: 1,044
