Mixing Paddle won't turn
Mixing Paddle does not turn whether in machine or out. Motor and pedestal for paddle work without pan but will not work in pan.
Ist dies eine gute Frage?
I had a similar problem, you need to perform the steps to replace the shaft seal then clean and lubricate the shaft. It may take a lot of force to remove the shaft. I used a dead blow rubber hammer and a drift to drive mine out. You need to be careful not to damage the shaft or bearing in the bread pan while driving the shaft out. As far as lube I used 3 in one oil but I’ll probably re-lube with silicone plumbers grease.
War diese Antwort hilfreich?
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 10
Insgesamt: 1,176
