Zum Hauptinhalt wechseln
Any series residential lawn tractors with Kohler or Briggs and Stratton engines.
21 Fragen Alle anzeigen
JD 2440 tractor, hydrolic fluid leaking from pet $!^& on top of pump.
when I close the pet $!^& I can’t raise or lower bucket, when I open the pet $!^& and let the fluid leak out then I have hydraulics again. The hydraulic resiour was way over filled from this issue? Is there a filter thats blocked? The hydraulic pump must be good or the bucket wouldn’t work when the pet $!^& is opened.
Thanks
Ron
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
Petcock is one word not two.
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Some Johne Deere front loaders have two pumps, an OC pump in the belly and a CC on the front it. It sounds like the one of the pumps is not putting out enough or you have contaminates in the priority valve.
Change the filter, remove the priority diverter valve on the left side of the tractor located between your left foot and rear axle make sure everything is clean before during and after.
Disassemble valve you will find a passage with a piston and spring remove and clean it. Remove the spring and put the piston back in bore and see if it moves freely back and forth. Run some 800 grit crocus cloth around piston and in the bore lightly. Clean up and blow out with air. Reassemble spring and piston the way you found them, install on tractor and try.
NOTE do not run tractor for long if the loader is not working this will ruin your front pump.
If this answer does not help go here for a live answer:
https://www.justanswer.com/sip/john-deer...
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
Ron Sullivan wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 11
Insgesamt: 286
