Zum Hauptinhalt wechseln
A 14'' touch-screen laptop created in 2014 by Toshiba
3 Fragen Alle anzeigen
Can't get to power on
Laptop won’t power on
have 19v at the power cord
Adaptor shows 19v
I have a orange light that indicates battery/plugged in status
-it is flashing orange
Power button flashes once when pushed, but no fan spin or post
Google search reveals very little
Any ideas?
Ist dies eine gute Frage?
Bewertung 0
3 Kommentare:
Hi @bvansick
Normally you will need laptop schematics to check on the mainboard,
e.g. if power is supplied correctly, etc from voltage regulator, MOSFET, etc
von
So I'm not sure what I did, but I put it back together and was able to get it on. I wonder if there was some kind of short in the DC power receptacle that I have temporarily fixed when I put it back together.
von
@bvansick
You probably just didn't connect something correctly first time.
Did you clean out dust?
von
Einen Kommentar hinzufügen
1 Antwort
Hi @bvansick
As you said "Power button flashes once when pushed, but no fan spin"
My guess is your laptop isn't getting the right electricity, it might be your power supply problem.
Did you take it to any service center?
(Note: Max time we use our laptop by plugging the charger. The power supply may be damaged due to this. So remember, try to use it after unplugging the charger every time.)
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Brentt VanSickle wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 5
Insgesamt: 142
