Zum Hauptinhalt wechseln
Repair guides and support for the laptop/tablet hybrid in the Toshiba Satellite Radius series released in 2014.
48 Fragen Alle anzeigen
No battery charge light, but battery reports 100% yet doesn't work
Slightly different than what others have been experiencing. No battery charging indicator light illuminates when plugged into AC power. Battery reports 100% on the indicator and shows good charge after running a battery report…so it seems like its recognized — yet when I try to use it without AC power the computer immediately dies. I’ve tried the uninstall battery method and it didn’t work. Neither did leaving it plugged in to trickle charge. I tested the power at the battery connection point on the motherboard. Without battery attached but AC adaptor not plugged in, I only got one reading: pin 7 at 3VDC. With the AC adaptor plugged in I got readings on pins 3 and 4 of 2.7VDC, pin 5 at 0.4, pin 7 at 3 and pins 8 & 9 at 0.7VDC. Worried that its a mobo problem vice a battery problem but looking for any suggestions. Thanks in advance!
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
laptop toshiba in no battery
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Denny wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 13
Insgesamt: 96
