Zum Hauptinhalt wechseln
Windows 10 is a major version of the Windows operating system. It was released in 2015.
22 Fragen Alle anzeigen
Why can't I install Windows 10?
I am trying to install Windows 10 via USB. I have formatted the USB, however, it doesn’t show up as UEFI. I have looked through BIOS and can’t find any way to change it. Additionally, sometimes when I reboot BIOS, i’ll receive the “Reboot and select proper boot device” message. Any help?
Specs:
MSI B450 Tomahawk Max
AMD Ryzen 5 3600
MSI 1070ti Aero
WD Blue 3D Nano SATA SSD M.2 2280
Corsair Vengeance DDR4 3600MHz
Corsair CX 550M
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
This question was migrated from https://meta.ifixit.com/Answers.
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
How are you writing the USB stick? If you’re using the Media Creation Tool, it writes it with a preference for UEFI boot modes on compatible systems. With these systems, you often need to have it set to UEFI boot for it to show as a boot option. In addition, you’re committing to keeping it as a “UEFI” system once you reinstall since changing back isn’t going to happen without a reinstall.
If you want to have some flexibility, you’ll need to use Rufus.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Justin Shifflett wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 12
Insgesamt: 138
