Zum Hauptinhalt wechseln
The Samsung Galaxy J3 Prime was the third release of the J Prime series, released in April 2017.
7 Fragen Alle anzeigen
phone battery replacement specs don't match the original- is it safe?
Took my 2017 samsung j3 (sm-j327a) to a repair shop to replace the battery. Original samsung battery specs were nominal voltage 3.8V, 9.88 Wh, charge voltage 4.35V, 2600 mAh. The shop gave me a Duracell CEL11669G which is 3.8V, 8.4Wh, 2200 mAh. Is it safe to use this battery in my phone?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
4 Antworten
Gewählte Lösung
@roborachel, that can be an issue in some cases; for example I have a drill that runs on Ni-Cd (nickel cadmium) batteries. I'd love to convert it to lithium ion, which would work fine for the drill, but the problem comes in when you try to charge it. A Ni-Cd charger will not put out the correct charge curve or voltage for a Li-Ion battery.
Cell phone batteries are a different story, The thing is, each and every cell phone, and most laptops for that matter, use a custom-designed battery. In general, a battery that's made for one phone won't go into another due to either the physical size and shape of the battery or the connector being different, not to mention any charge, voltage or temperature sensors built into the battery.
So for cell phones you won't find a battery that says it's made for your phone that's incompatible; in fact, just the opposite is true - if it doesn't say it's made for your phone, you can assume it won't work.
So if someone is selling a battery for a Samsung Galaxy J3 Prime, then it's basically always safe to assume it's compatible. It's actually fairly rare for a replacement battery to have different specifications than the original, but that's not always the case as you found out. In your case the new battery you got doesn't hold quite as much charge as your old one did; about 15% less than the original.
It won't hurt anything; the battery itself will work fine, but you'll end up having to charge it a little bit more frequently than you did with the original battery.
On the other side of the spectrum are batteries being sold as some sort of 'gold standard' that are supposed to hold amazingly more charge; unfortunately those claims never hold up under scrutiny; just ask @oldturkey03 about that; he's written papers on the subject after testing those supposed high capacity batteries and found that their claims aren't true.
The upshot to all this is, while I'd have been a little miffed at getting a battery with less capacity than it did when I took it in - and you would have a reasonable complaint with them if it bothers you - the battery they gave you should work fine for your phone for the life of the battery.
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
thank you so much!!
von
Hilfreichste Antwort
@roborachel yes it is. The replacement has a little less "oomph" but should not pose a problem.
Bewertung 2
3 Kommentare:
thank you! are there any guidelines for how to tell if a battery is compatible with a cell phone or not?
von
also, what kinds of problems can happen when a battery isn't compatible?
von
@roborachel like my esteemed colleague @dadibrokeit mentioned in his excellent explanation, it is the capacity issue. The one you received has less capacity so it won't last you quite as long.
von
Yes it is safe and sound for your phone. You dont have to be skeptical for the help of your mobile, just for it.
Bewertung 1
It is not threatening. It does not affect the optimal activity of your phone.
Bewertung 0
Antwort hinzufügen
rachel wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 5
Letzte 30 Tage: 49
Insgesamt: 622
