Zum Hauptinhalt wechseln
Der PowerMac G5 ist ein Desktop-Computer, der erstmals 2003 von Apple Corporation produziert wurde. Diese Anleitung zeigt dir, wie du den PowerMac G5 (Modellnummer A1047, EMC: 2061, von 2004) reparieren kannst.
197 Fragen Alle anzeigen
won't power on, I just smack the machine and then it powersup
I have similar issues , it seems to be a cold/cracked solderjoin somewhere , I just pull plug , drain caps , replug , sit 20m so caps will charge then power-up , if no reaction i just smack the machine and then it powersup. (eventually). - Unable to determine location , may be in the PSU(the issue).
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
There's a specific issue with the G5 tower having a tendency to fail due to solder problems on the lead-free machines; the ones with leaded solder never had an issue.
It's the chip with the massive heatsink that goes bad on these, but the best practice is to treat both as bad because one going out is not so great; the other one tends to go out next. However, this is a TEMPORARY SOLUTION and not permanent. For a longer-term solution, you will need to replace the motherboard and ASD; you can look online for it, but I'm not providing a link (COUGH Macintosh Repository COUGH) once you calibrate the processors AND replace the motherboard that fixes the problem.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
ediflorianUS wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 5
Insgesamt: 22
