Zum Hauptinhalt wechseln
The second generation of the Recreational Active Vehicle with 4-Wheel Drive, commonly known as the RAV4.
22 Fragen Alle anzeigen
How fix the clutch paddle when it's stuck and can't go back it's own
I found that when I put my foot in the clutch paddle to $@$* a gear. It's not return back to its own position I reckon there is no pressure to return it back so I can't drive and shift gear. It's rave4 2003 2.4L manual
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare
Hi @samalex,
Have you checked the level of the fluid in the clutch master cylinder, located in the engine bay, you didn't say?
von
I have checked it , the level is not like normal it went down
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
@samalex sounds like you may have a leak in the hydraulic system of your clutch. Could be the master or the release cylinder as well as the clutch line. Check the part from the SM that deals with the Rav4 Clutch. You may have to crawl under your RAV4 to see where the leak is and what to change.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Sam alex wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 18
Insgesamt: 18
