Akku
1 Antwort 0 Punkte |
HDMI Port defekt wegen Wasserschaden |
2 Antworten 0 Punkte |
Do hard shell cases affect performance? |
Some water got into ports due to rain, what do I do? |
HDMI port defective due to water damage corrosion |
Ersatzteile
Werkzeuge
Es werden ein paar gängige Werkzeuge verwendet, um an diesem Gerät zu arbeiten. Du wirst nicht jedes Werkzeug für jeden Schritt benötigen.
Modelle
A2779 (MacBookPro14,5 2023) M2 Max 12 CPU/30 GPU, A2779 (MacBookPro14,5 2023) M2 Max 12 CPU/38 GPU, A2779 (MacBookPro14,9 2023) M2 Pro 10 CPU/16 GPU, A2779 (MacBookPro14,9 2023) M2 Pro 12 CPU/19 GPU
Background
Released in January 2023, the latest 14" MacBook Pro gets an upgrade with Apple's also-new-for-2023 M2 Pro and M2 Max SoCs, featuring up to 12-core CPUs and up to 19-core or 38-core GPUs respectively. Both the updated 16" MacBook Pro and its bigger 16" MacBook Pro sibling share many of the same features introduced in 2021's MacBook Pro, including the same ports, ProMotion HDR mini-LED displays, 1080p webcams with a display notch, full-size function keys, and the distinctive blacked-out keyboard. Small, yet notable other upgrades for 2023 include a jump to Wi-Fi 6E, HDMI 2.1, and Bluetooth 5.3.
Starting at a base price of $1999, the 2023 14" MacBook Pro is available in either Silver or Space Gray.
Identification
Identify your MacBook Pro by the model number printed on its back cover.
You can also find the model number through macOS by choosing About This Mac from the Apple menu in the upper-left corner of the screen.
Additionally, Apple offers a quick online tool to help identify your devices: Identify your MacBook Pro model.
News
Technical Specifications
Display
- 14.2" Liquid Retina XDR mini-LED display with True Tone; 3024 x 1964 pixels (254 ppi); ProMotion adaptive refresh rate (up to 120 Hz); HDR, P3 wide color gamut; 1000 nits sustained, 1600 nits peak brightness
Processor
- Apple M2 Pro 10-core CPU, 16-core Neural Engine
- (Configurable to) Apple M2 Pro 12-core CPU, 16-core Neural Engine
- (Configurable to) Apple M2 Max 12-core CPU, 16-core Neural Engine
Graphics
- Apple M2 Pro integrated 16-core GPU
- (Configurable to) Apple M2 Pro integrated 19-core GPU
- (Configurable to) Apple M2 Max integrated 30-core GPU
- (Configurable to) Apple M2 Max integrated 38-core GPU
Storage
- 512 GB PCIe-based SSD, configurable to 1 TB, 2 TB, 4 TB, or 8 TB.
Memory
- 16 GB of unified LPDDR5 memory, configurable to 32 GB (M2 Pro or M2 Max), 64 GB (M2 Max), or 96 GB (M2 Max with 38-core GPU)
Wireless
- 802.11ax Wi-Fi 6E wireless networking; IEEE 802.11a/b/g/n/ac compatible
- Bluetooth 5.3 wireless technology
Battery
- Built-in 70-watt-hour lithium-polymer battery
- Up to 12 hours of web browsing, up to 18 hours of Apple TV app video playback
Dimensions
- Height: 0.6 in (1.55 cm)
- Width: 12.31 in (31.26 cm)
- Depth: 8.71 in (22.12 cm)
- Weight: M2 Pro: 3.5 lbs (1.6 kg), M2 Max: 3.6 lbs (1.63 kg)
Ports
- MagSafe 3 charging port
- 3× Thunderbolt USB-C ports (Thunderbolt 4 / USB 4 / DisplayPort / charging)
- HDMI 2.1 port
- SDXC card slot
- 1× 3.5 mm headphone jack
