Mophie PowerStation 5X Teardown
2 Antworten 0 Punkte |
2 x 4.5 volt units, and 1 x 9 volt DC power block |
Keine Antworten 0 Punkte |
Power bank only powers device when plugged in to wall |
If the battery is not recognized by your computer, how to solve it? |
Why my battery not wet why I can't open my laptop? |
Werkzeuge
Es werden ein paar gängige Werkzeuge verwendet, um an diesem Gerät zu arbeiten. Du wirst nicht jedes Werkzeug für jeden Schritt benötigen.
Background and Identification
The Mophie PowerStation 5X is a portable charger that can charge a variety of devices, including smartphones, tablets, and smartwatches. The Mophie PowerStation 5X comes with a USB charging cable that plugs into a USB port or USB AC adapter, meaning you can charge the Mophie PowerStation 5X from a computer or from a wall outlet. The Mophie PowerStation 5X also has two USB charging ports, allowing it to charge multiple devices at the same time.
The Mophie PowerStation 5X also connects to a compatible smartphone with the Mophie Power app. This app allows the user to monitor the battery level of the charger and receive notifications when it is low on charge or finished charging.
The Mophie PowerStation 5X is a thin, rectangular portable charger with ports on the side. It is silver in color and has the Mophie logo along the edge. As of summer 2020, this portable charger has been discontinued by Mophie, although the company does make a wide range of other portable chargers.
Specifications
- Dimensions: 3-3/4"W x 6-3/4"H x 3/8"D
- Weight: 9.9 ounces
- Battery: lithium polymer, 10,000 mAh
- Warranty: 2 years
- In the Box:
- Battery pack
- USB charger
- 35” microUSB-to-USB cable
- Warranty & Legal info
- Quick Start Guide
