Camera
Beliebte Fragen im Forum
Eine Frage stellenEs gibt noch keine Fragen. Stelle du die erste!
Werkzeuge
Es werden ein paar gängige Werkzeuge verwendet, um an diesem Gerät zu arbeiten. Du wirst nicht jedes Werkzeug für jeden Schritt benötigen.
Troubleshooting
If you are experiencing difficulties with your Nest Cam IQ and need additional help, refer to the troubleshooting page.
Background
With its high-resolution 8-megapixel (4K) color sensor, 12x digital zoom, it's all-glass lens with a 130° diagonal wide-angle field of vision, and super sight close up tracking view while providing a video up to 1080p at 30 frames/sec and night vision, the Nest Cam IQ offers a level of security and convenience previously unseen in consumer-grade cameras. The Nest Cam IQ can detect and respond to security threats efficiently, as it provides a high-quality speaker with 3-microphone array that allows you to talk to and listen through the camera. The Google Nest Cam IQ is a lightweight, average sized home security and surveillance device. This 1/2.5-inch camera system is designed to seamlessly blend into the modern home environment while delivering its purpose.
Identification
The Nest Cam IQ is an average-sized video recorder. The camera is held up by a stand which can be mounted to a wall. To identify the device, the model number is located on the bottom of the Nest Cam IQ.
Technical Specifications
Camera Dimension
- 4.9 in x 2.9 in x 2.9 in (12.4 cm x 7.4 cm x 7.4 cm)
Camera Weight
- 12.6 oz (357 g)
Cable Length
- 10 ft (3 m)
Power Adapter Input
- 100-240V AC
- 50/60 Hz
- 0.65A
Power Adapter Output
- 15V DC
- 1.87A
Camera Input
- 15V DC
- 1.0A
Camera
- 1/2.5-inch
- 8-megapixel (4K) color sensor
- 12x digital zoom
- Super sight close up tracking view
Video
- Up to 1080p (1920 x 1080) at 30 frames/sec
- H.264 encoding
- High Dynamic Range (HDR)
Field of Vision
- 130° diagonal wide-angle view
- All-glass lens
Audio
- High-quality speaker
- 3-microphone array
- HD Talk and Listen
Night Vision
- High-power infrared LEDs (940 nm)
Source: Technical specs for Nest cameras and doorbells - Google Nest Help
