3 Antworten 16 Punkte |
I forgot my lock screen pin. |
3 Antworten 4 Punkte |
Why is the battery not charging |
8 Antworten 7 Punkte |
How do you remove the back cover? |
1 Antwort 1 Punkte |
My phone stops turning on (black screen) |
Technical Specifications
Announce date: December 17, 2019
The Samsung Galaxy A01 has 2 sub different sub-models: USB-C Frame and Micro USB Frame. Most parts are interchangeable between the sub-models; however the LCD’s and charging circuit board are not. This is due to the Micro USB Frame being 1mm shorter than the USB-C Frame.
USB-C Frame Model: SM-S111DL, SM-A015V, SM-A015A
Micro USB Frame Model: SM-A015F, SM-A015F/DS, SM-A015G, SM-A015G/DS, SM-A015M, SM-A015M/DS,
Developer: Samsung
Operating System: Android 10, One UI 2
Display:
- Type: PLS IPS
- Size: 5.7 inches, 81.6 cm2 (~78.8% screen-to-body ratio)
- Resolution: 720 x 1520 pixels, 19:9 ratio (~294 ppi density)
Fingerprint reader: No Reader
Camera: Contains both front and rear facing cameras.
- MAIN CAMERA
- Dual: 13 MP, f/2.2, 28mm (wide), 1/3.1", 1.12µm, AF
2 MP, f/2.4, (depth) - FeaturesLED flash
- Video1080p@30fps
- SELFIE CAMERA
- Single: 5 MP, f/2.2, 1/5", 1.12µm
Processor: Qualcomm SDM439 Snapdragon 439 (12 nm)
RAM: 2 GB
Storage: 16, 32 GB Flash Memory
Sensors:
- Accelerometer
- Proximity sensor
Wireless Connectivity:
- Integrated 802.11 a/b/g/n/ac Wi-Fi with MIMO
- Bluetooth 4.2
- GSM, CDMA, 3G, EVDO, HSPA+, LTE
- Digital Compass
- GPS and GLONASS signal reception
- NFC
USB-C Frame Dimensions: 146.2 x 70.9 x 8.3 mm (5.76 x 2.79 x 0.33 in)
Micro USB Frame Dimensions: 145.2 x 70.9 x 8.3mm (5.71 x 2.79 x 0.33 in)
Weight: 149 g (5.26 oz)
Colors: Black, Blue, Red
