Keine Antworten 0 Punkte |
reboot and select proper boot device windows 8 laptop how to fix it 8 |
Laptop getting restart automatically |
Dokumente
This laptop is in the same series as the Toshiba Satellite P875, and the chassis is similar to the one featured in the dynabook Satellite T572/T772 and Qosmio X870/X875. Therefore, repair guides for those models should work with this model as well
Specifications
Note: most of this information is taken from the P870 Maintenance Manual that is attached.
Toshiba Satellite P870/P875 & dynabook Satellite T572/T772 & Qosmio X870/X875 is a full size notebook PC based on the mobile Intel Sandy/Ivy Bridge Processor, providing high-speed processing capabilities and advanced features. The computer employs a Lithium-ion battery that allows it to be battery-operated for a longer period of time. The display uses a 17.3-inch HD+ or Full HD LCD panel, at a resolution of 1600x900 or 1920x1080. The RPGA Socket supports BTO/CTO for the CPU so that the system can be designed to suit your needs.
Processor
- Intel Sandy Bridge:
- Intel Core i7 CPU (1333MHz FSB)
- Core i7-2670QM (2.2 GHz)
- Intel Ivy Bridge:
- Intel Core i3 CPU (1600MHz FSB)
- Core i3-3110M (2.4 GHz) (only for F/FG)
- Intel Core i7 CPU (1600MHz FSB)
- Core i5-3210M (2.5 GHz)
- Core i7-3610QM (2.3 GHz)
- Core i7-3720QM (2.6 GHz)
- Core i7-3820QM (2.7 GHz)
Graphics
- Intel integrated graphics for F
- nVIDIA N13P-GL DDR3 1 GB/2 GB on board discrete graphics for FG
- nVIDIA N13E-GS1-LP DDR5 3 GB discrete graphics board for FH
Memory
The computer has two or four SO-DIMM slots (BTO), which come standard with DDR3-1600MHz (PC3-12800) memory module. DDR3 is driven at 1.5V. It accepts BTO/CTO for your memory requirements. It can incorporate up to 32.0 GB of main memory.
Using the following sizes of memory modules:
- 2048 MB (256M×64) / DDR3-1600MHz
- 4096 MB (512M×64) / DDR3-1600MHz
- 8192 MB (1024M×64) / DDR3-1600MHz
Storage
The computer accommodates two 2.5-inch 7/9.5 mm height Serial ATA HDD with
following storage capacities:
- 500 GB (7 mm thick) SATA (5,400rpm)
- 500 GB (9.5 mm thick) SATA (5,400rpm)
- 640 GB (9.5 mm thick) SATA (5,400rpm)
- 750 GB (9.5 mm thick) SATA (5,400rpm)
- 1 TB (9.5 mm thick) SATA (5,400rpm)
- 500 GB (9.5 mm thick) SATA (7,200rpm)
- 750 GB (9.5 mm thick) SATA (7,200rpm)
The computer accommodates two 2.5-inch 7 mm height Serial ATA SSD with
- 64 GB (7 mm thick) SATA
- 128 GB (7 mm thick) SATA
- 256 GB (7 mm thick) SATA
- 512 GB (7 mm thick) SATA
Optical disk drive
The computer accommodates a fixed 12.7 mm ODD with one of following types:
- Tray Type DVD Super Multi ±R Double Layer drive
- Tray Type Blu-ray Combo BD-ROM drive
- Tray Type Blu-ray Writer BD-RE drive
- Tray Type Blu-ray Writer BD-RE(BDXL) drive
Display
LCDs come in the following types:
- 17.3” HD+ 1600x900 CSV LED display
- 17.3” Full HD 1920x1080 CSV LED display
LAN
The internal LAN supports 10/100Mbit or 10/100/1000Mbit Ethernet. It supports Wake-up on LAN from S3/S4/S5 and PXE boot support. This internal LAN has an RJ45 jack to directly accommodate a LAN cable.
The internal PCI Mini slot supports IEEE802.11b/g/n (MOW) Wireless LAN card; WLAN + Bluetooth combo card is also supported. One or two or three antennas depending on module.
