Beliebte Fragen im Forum
Eine Frage stellenEs gibt noch keine Fragen. Stelle du die erste!
Dokumente
These heaters are ETL approved for permanent installations and electrical connections. Built with splash proof construction, the conducting parts are protected against water. All wiring must be performed in accordance with national and local codes. See Diagram2for wire and room size requirements. These heaters are wall mounted.
The NTSA series sauna heater is equipped with NTS-100 on-heater digital control panel while the NTSC series sauna heater is equipped with NTS-300 wall-mounted digital control panel. Control panel NTS-300and NTS-100 are designed for family use only.
NTSA and NTSC series sauna heaters are designed for small sauna rooms.
NTSA 30-90: 17 3 /4” W×15” D×24 3 /4”H
NTSC 30-90: 17 3 /4” W×11 3
