CPU
1 Antwort 0 Punkte |
Freezingscreen while or after boot |
3 Antworten 6 Punkte |
Power Supply pin (voltage, start other?) |
3 Antworten 2 Punkte |
What is a CR-VPH2 screwdriver bit |
6 Antworten 2 Punkte |
Can I upgrade early 2009 iMac Graphics card |
Ersatzteile
Werkzeuge
Es werden ein paar gängige Werkzeuge verwendet, um an diesem Gerät zu arbeiten. Du wirst nicht jedes Werkzeug für jeden Schritt benötigen.
Modelle
2.66 GHz (iMac9,1), 2.93 GHz (iMac9,1), 3.06 GHz (iMac9,1)
Troubleshooting
There are no troubleshooting guides for the iMac Intel 24" EMC 2267 at this time.
Parts
Check our store to find the iMac Intel 24" EMC 2267 parts you need.
Upgrades
You can cost-effectively upgrade a number of components in the iMac Intel 24" EMC 2267.
- Memory: If your iMac is still running with only the stock RAM, upgrading will provide a dramatic performance boost at minimal cost. Upgrading to the maximum of 8 GB (Two 4 GB sticks) provides unmatched performance.
- Hard Drive: 640 GB or 1 TB hard drives came standard with the iMac Intel 20" EMC 2266. You can upgrade the drive up to 2 TB.
Identification and Background
You can verify that you have a iMac Intel 24" EMC 2267 by checking the processor information through "About This Mac" in the Apple menu.
Use the iMac identification system to help you identify your machine. iMacs tend to look very similar, and it's important to know which machine you have before ordering any replacement parts.
The iMac Intel 24" EMC 2267 looks nearly identical to the first generation aluminum iMacs. The differences lie within, with the most noticeable hardware change to the base model being a surface mount GPU soldered directly to the motherboard as opposed to a removable video card on earlier aluminum iMacs. The versions sold with the upgraded nVidia or ATI graphics do feature a replaceable video card.
The style of the new aluminum iMacs are a dramatic departure from the white plastic encased iMacs of the past. The aluminum iMacs were to match the design of the original iPhone, both released at nearly the same time. The glass front panel allows for a richer viewing experience, and even with aluminum and glass accents the 24" aluminum iMac is still lighter than all previous 24" iMac generations.
