Zum Hauptinhalt wechseln
GoPro Hero4 Black Lens Replacement
Was du brauchst
  1. GoPro Hero4 Black Lens Replacement, Midframe Housing: Schritt 1, Bild 1 von 3 GoPro Hero4 Black Lens Replacement, Midframe Housing: Schritt 1, Bild 2 von 3 GoPro Hero4 Black Lens Replacement, Midframe Housing: Schritt 1, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Remove the faceplate by carefully prying around the edge using a plastic opening tool. Loosen the clips on the edge, then pull the faceplate off.
    • Use the tweezers to lift the faceplate from the rest of the device.
    • The power button on the front of the GoPro may pop off. Ensure to align it properly during reassembly.
  2. GoPro Hero4 Black Lens Replacement: Schritt 2, Bild 1 von 2 GoPro Hero4 Black Lens Replacement: Schritt 2, Bild 2 von 2
    • Using a #00 Phillips head screwdriver, remove the following screws:
    • One 4.6 mm screw
    • Three 8.2 mm screws
    • Two 6.1 mm screws
  3. GoPro Hero4 Black Lens Replacement: Schritt 3, Bild 1 von 2 GoPro Hero4 Black Lens Replacement: Schritt 3, Bild 2 von 2
    • Insert a metal spudger between the back plastic housing and the camera board assembly. Working around the edge to be careful of the inner components, carefully remove the camera.
  4. GoPro Hero4 Black Lens Replacement: Schritt 4, Bild 1 von 3 GoPro Hero4 Black Lens Replacement: Schritt 4, Bild 2 von 3 GoPro Hero4 Black Lens Replacement: Schritt 4, Bild 3 von 3
    • Using tweezers, remove the ribbon strip by pulling on it. This will remove the connection.
    • Push down on the three wires with the metal spudger and the clip will disconnect from the motherboard.
    • The clip must be pulled up and away from the motherboard. Attempting to slide it out will damage the clip.
    • During reassembly, remove the black tape on the ribbon cable, turn the camera upside down so you can see the port, and reinsert the cable with tweezers. It's a lot easier!
  5. GoPro Hero4 Black Lens Replacement, Camera Sensor: Schritt 5, Bild 1 von 3 GoPro Hero4 Black Lens Replacement, Camera Sensor: Schritt 5, Bild 2 von 3 GoPro Hero4 Black Lens Replacement, Camera Sensor: Schritt 5, Bild 3 von 3
    • Using a plastic opening tool, separate the camera sensor's connector from the motherboard.
  6. GoPro Hero4 Black Lens Replacement: Schritt 6, Bild 1 von 3 GoPro Hero4 Black Lens Replacement: Schritt 6, Bild 2 von 3 GoPro Hero4 Black Lens Replacement: Schritt 6, Bild 3 von 3
    • Using a #00 Phillips head screwdriver, remove the four 3.0mm screws holding the camera sensor.
  7. GoPro Hero4 Black Lens Replacement, Lens: Schritt 7, Bild 1 von 2 GoPro Hero4 Black Lens Replacement, Lens: Schritt 7, Bild 2 von 2
    • Three 2 mm screw
  8. GoPro Hero4 Black Lens Replacement: Schritt 8, Bild 1 von 1
    • Lift the lens from the front housing.
Abschluss
5 weitere Nutzer:innen haben diese Anleitung absolviert.
USF Tampa, Team S2-G1, Sullivan Spring 2017 Mitglied von USF Tampa, Team S2-G1, Sullivan Spring 2017
USFT-SULLIVAN-S17S2G1
4 Mitglieder
12 Anleitungen geschrieben
Ein Kommentar
Between step 6 and step 7, you skipped a really important step…
Matthew Mulholland - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 22
Insgesamt: 4,299
