Zum Hauptinhalt wechseln
How to Apply a Screen Protector for iPhone11 Pro Max
Was du brauchst
  1. How to Apply a Screen Protector for iPhone11 Pro Max, How to Apply a Screen Protector for iPhone11 Pro Max: Schritt 1, Bild 1 von 2 How to Apply a Screen Protector for iPhone11 Pro Max, How to Apply a Screen Protector for iPhone11 Pro Max: Schritt 1, Bild 2 von 2
    • Wipe the dust off the screen with a No. 1 alcohol cleaning wipe.
    • This will help to avoid bubbles when applying the screen protector.
  2. How to Apply a Screen Protector for iPhone11 Pro Max: Schritt 2, Bild 1 von 1
    • Use a dry wipe to wipe off any water stains on the screen.
  3. How to Apply a Screen Protector for iPhone11 Pro Max: Schritt 3, Bild 1 von 3 How to Apply a Screen Protector for iPhone11 Pro Max: Schritt 3, Bild 2 von 3 How to Apply a Screen Protector for iPhone11 Pro Max: Schritt 3, Bild 3 von 3
    • Tear off one of the dust removal tape strips.
    • Use the dust removal tape to clean off the fine dust.
  4. How to Apply a Screen Protector for iPhone11 Pro Max: Schritt 4, Bild 1 von 3 How to Apply a Screen Protector for iPhone11 Pro Max: Schritt 4, Bild 2 von 3 How to Apply a Screen Protector for iPhone11 Pro Max: Schritt 4, Bild 3 von 3
    • Put the auxiliary tool on your phone.
    • Push down so that the auxiliary tool is firmly attached to the phone.
    • This step is not necessary, and it doesn't matter if you don't have it. The auxiliary tool is just to assist you place the screen protector straight.
  5. How to Apply a Screen Protector for iPhone11 Pro Max: Schritt 5, Bild 1 von 3 How to Apply a Screen Protector for iPhone11 Pro Max: Schritt 5, Bild 2 von 3 How to Apply a Screen Protector for iPhone11 Pro Max: Schritt 5, Bild 3 von 3
    • Take out the screen protector. Tear off the release layer of the screen protector (the thinner side).
    • Aim the holes of the screen protector at the holes of the auxiliary tool and then slowly lay the screen protector onto the screen.
  6. How to Apply a Screen Protector for iPhone11 Pro Max: Schritt 6, Bild 1 von 3 How to Apply a Screen Protector for iPhone11 Pro Max: Schritt 6, Bild 2 von 3 How to Apply a Screen Protector for iPhone11 Pro Max: Schritt 6, Bild 3 von 3
    • Wipe the screen surface around with a dry wipe to make the screen protector fit the phone screen better and lay flat.
  7. How to Apply a Screen Protector for iPhone11 Pro Max: Schritt 7, Bild 1 von 3 How to Apply a Screen Protector for iPhone11 Pro Max: Schritt 7, Bild 2 von 3 How to Apply a Screen Protector for iPhone11 Pro Max: Schritt 7, Bild 3 von 3
    • Pull off the the auxiliary tool with your fingers.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Qiyuan Feng
169 Reputation
1 Anleitung geschrieben
York University, Team S1-G6, O'Regan Summer 2021 Mitglied von York University, Team S1-G6, O'Regan Summer 2021
YORK-O'REGAN-SU21S1G6
1 Mitglied
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 10
Letzte 30 Tage: 47
Insgesamt: 1,980
