Was du brauchst
Unscrew the three screws from the back panel with Phillips #0 screwdriver.
Remove the back panel.
Locate the two clips holding the RAM chip in place.
Apply pressure to each clip, pulling them away from the RAM.
To intall a new stick of RAM, carefully insert it into into the RAM slot.
Gently push down on the RAM chip until it snaps securely into place.
Fast fertig!
Abschluss
