Zum Hauptinhalt wechseln
iMac G5 17" Model A1058 Bluetooth Board Replacement
Was du brauchst
  1. iMac G5 17" Model A1058 Bluetooth Board Replacement, Rear Panel: Schritt 1, Bild 1 von 1
    • Lay the iMac display-side down on a flat surface.
    • Loosen the three Phillips screws securing the rear panel to the iMac.
    • These screws are captive in the iMac. The center screw will stop turning after about 3.5 turns and the outer screws will stop turning after about 5.5 turns. Do not try to remove these screws from your iMac.
  2. iMac G5 17" Model A1058 Bluetooth Board Replacement: Schritt 2, Bild 1 von 3 iMac G5 17" Model A1058 Bluetooth Board Replacement: Schritt 2, Bild 2 von 3 iMac G5 17" Model A1058 Bluetooth Board Replacement: Schritt 2, Bild 3 von 3
    • Lift the rear panel slightly from the bottom edge of the iMac.
    • Pull the rear panel toward yourself and remove it from the iMac.
  3. iMac G5 17" Model A1058 Bluetooth Board Replacement, Bluetooth Board: Schritt 3, Bild 1 von 1
    • Remove the two 5.5 mm T6 Torx screws securing the Bluetooth board to the logic board.
  4. iMac G5 17" Model A1058 Bluetooth Board Replacement: Schritt 4, Bild 1 von 2 iMac G5 17" Model A1058 Bluetooth Board Replacement: Schritt 4, Bild 2 von 2
    • Bend a paper clip into a hook and use it to pull the Bluetooth board up off its socket on the logic board.
    • You may use a spudger to remove the Bluetooth board, but be sure to only apply upward force as any sideways force may cause the connector to shear off the Bluetooth board.
  5. iMac G5 17" Model A1058 Bluetooth Board Replacement: Schritt 5, Bild 1 von 1
    • Use a spudger to pry the Bluetooth antenna connector up off the Bluetooth board.
Abschluss
10 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
WARNING: The last iMac G5 17" ALS (no isight) to be made does NOT have a dedicated bluetooth board.
I followed this guide and ended up removing the fax/data modem which is above the bluetooth board in this guide.
The last iMac G5's (17" no isight) to be made have a Airport Extreme/Bluetooth combo board:
http://www.applemacparts.co.uk/store/pow...
This is located to the right of the battery.
Ben Goodman - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 11
Insgesamt: 15,962
