Einleitung
A look inside the Facebook Portal TV.
Was du brauchst
Features:
Smart Camera and Smart Sound
Alexa Built-in
Easy to Disable Camera and to Disable Microphone with push of button or blocking camera lens
Video Calling via Facebook, and Messenger
120 Degrees Field of View
12.5MP Camera Resolution
Far-field 8-Microphone Array
View of the product from the outside
Power connector
HDMI Output
USB C Interface
Button to disable Microphone and Camera
Camera Cover Slide
System LED
At first there didn't seem to be way into this device
Flipping the device upside down, there was cover between the enclosure, and the base. Removing this cover revealed sixteen T5 screws
Removing the sixteen screws, only removed the base
There was still no obvious way into to the product
It was time to get the Spudger Tool out and test a few edges
Working along the front edge, it appeared that the face plate was glued or held in place with double stick tape
The Spudger Tool was use to loosen a gap along the face plate edge
A Jimmy Tool was used to further release face plate
With the face plate removed
we can see the led light pipe
we can also see the camera shut off switch
LED Light Pipe
At this point we close to getting into this device
Now we are confronted with eight more T5 Screws
Time to get the Spudger Tool out and pry along the face again
This face plate houses the camera and speaker
With the face plate pulled back, we are confronted with two more T5 screws in the very back of the unit on the left and right of the product
We are much closer now to opening up the unit and getting access to the electronics inside
As mentioned in the last step, there are two T5 screws in the back of the unit
Just when we thought we had all the screws removed, the switch on the side unit is stopping the electronics from being pulled out of the enclosure. It has two T2 screws holding it in place
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
We can now use tweezers to remove the speaker cable attaching the front panel to the rest of the enclosure.
Then we can slide out the metal enclosure that holds the electronics from the main enclosure
Now use we can use tweezers to flip up the flex cable lock latch to release the flex cable attached to the main electronics in the metal enclosure and outer body. As will be seen shortly, this cable goes to a microphone array PCB in top of the outer enclosure
Now with the outer enclosure removed, and the front plate removed we can work on opening up the metal enclosure that contains the main electronics
The metal enclosure is held together with eight T5 screws. Use a T5 tool to remove these screws
The metal enclosure is also held together on each outer end with a flexible sticker type antenna. These flexible antenna will have to be removed before the metal enclosure can be opened up
Unfortunately, removing the flexible antennas will destroy them. Since the antenna are flexible, and have adhesive use to hold them in place. However, It may be possible to remove the antennas and use some adhesive to hold them in place when putting the unit back together
Use tweezers to remove the flexible antennas on each end of the metal enclosure
With the metal enclosure screws removed, and the flexible antennas removed from each side of the metal enclosure, the metal enclosure can be opened to give us the first look at the electronics within
We also see that the metal enclosure is not meant for much RF Shielding as much as it is meant for cooling and weighting down the product.
The cooling is via a copper heat pipe
Now it is a good time to remove the side button flex cable from the bottom side of the unit.
This can be done by using tweezers to remove the plastic film over the button connector. Then using tweezers to lift up the connector latch and to pull the button flex cable free
Before we can get a closer look at the electronics, we also need to remove the u.fl Antenna cables that attached to the main electronics board
A Spudger Tool can be used to pry up and off the Antenna cables from u.fl connectors
Now use a Spudger Tool to remove the main electronics board from the metal enclosure
With the main electronics board removed, we can now remove the camera that is attached
To do this, first remove the plastic film over the camera connector. Then remove camera flex cable by prying up on the connector latch and siding out the camera flex cable free with tweezers
Camera flex cable is also held in place via a thick plastic block attached to the main electronics PCB. This plastic block can be pulled away from the PCB
Now that we have the main electronics PCB removed, we turn our attention back to the small electronic PCB locate in the top of the main enclosure
As can be seen in the first step photos of this teardown, there are eight pin holes in the top of the main enclosure. These pin holes are for the microphone array. The holes pass sound to the eight MEMS Micrphones below the pin holes
On the opposite out side of the main enclosure, we see eight circle holes. These hole are covered on the inside by black tape
We can use tweezers to punch a holes in the black tape to give access to the screws that hold the microphone array PCB on the opposite side of the enclosure
Once we have holes punched in the tape we use a T2 Tool to remove the screws holding the Microphone PCB in enclosure
After the microphone array PCB mounting screws have been removed, we can just Spudger Tool to pry the PCB free. It is also held in place with double stick tape in addition to the screws
Once the Microphone Array board has been removed, we can get a closer look at it
Now we can turn our attention to separating the camera from the front panel cover
Use a Spudger Tool to remove pry up on the metal tab attaching the camera to the front cover
Now we can separate the Speaker from the front cover
The speaker is held in place with four T2 Screws. Use a T2 Tool to remove these screws
Turning our attention back to the main electronics PCB, we need to remove the RF Shielding so we can see components under the RF Shields
Use a pick tool to remove each RF Shield. The RF shields are only snapped in place and can be easily removed
Now flip the main electronics board over and remove two more RF Shields
Use a dental pick tool to remove these RF Shields
With the RF Shielding removed, we can take a closer look at the components on the PCB. The main SoC is underneath the Sk Hynix Memory, and not easy to access. Sk Hynix also makes image processors, so it could be their SoC/Imager. A number of parts could not be crossed referenced, if you have information on a part please leave it in the comments
FLH - could not cross reference
DSP Group D7A1C Audio DSP
Sk hynix H9Hknnncrmmuernmh LPDDR4 32GB 256Mx16 PC3733
Qualcom PM8998 Power Management IC (PMIC)
Qualcom WCN3990 - WiFi 2.4Ghz, 5Ghz, 2x2, Dual-band concurrent, 802.11ac
Qualcom 3C/485Z - could not cross, but may be Power Amplifiers for WiFi
AW9109 - could not cross, but may be an LED driver IC from Shanghai Awinic Technology
With the RF Shielding removed from the backside, we can take a closer look at the electronics on this side of the PCB. Also, a number of parts could not be crossed, so if you have information on a part please leave in the comments
8mB / +19C / 10 - could not cross reference
894A / A1 12 / +9228 - could not cross
Qualcom PMI8998 - Power Management IC. Used with PM8998 (other side of the PCB)
Sinopower - SM3337 - P-Channel MOFET
SanDisk Embedded 32GB Flash Disk
Qualcom PM8005 Power Management IC
Now we turn our attention to the microphone array board
We can see that one side of the board has ports (holes) for the microphones
The other side of the board has the eight MEMs Micophones
Infineon IM69D130 MEMS Microphone
Now let us review the camera in the unit. The camera lens and imager are combine and not easily separated.
The Camera could not be crossed reference with the marking on the camera flex cable. There are no markings on the camera body.
Next, let us review the speaker
Speaker part number - 8GVRMS138N9454 - could not cross reference
Close view of some of the components
As mention earlier the SK hynix DRAM is bonded over the main SoC
More component close up views
Qualcom PMI8998 - Power Management IC. Used with PM8998 (other side of the PCB)New line.
Qualcom WCN3990 - WiFi 2.4Ghz, 5Ghz, 2x2, Dual-band concurrent, 802.11ac, and Qualcom 3C 485Z - possible Power Amplifiers for WiFi Radio
8 Kommentare
That's a beautiful processor
Step 5 has a mistake.
I assume the author meant to say, 8 t2 scews (where they said t5) - as the required tool list has a t2 listed… However, my portal tv had 8 t3 screws here, NOT t2!
What is the voltage and amperage for the power supply? Do you know the diameter of the barrel plug?
The power supply is 12v DC 2 amps. I too am looking for the barrel connector size. I want to replace the power supply with a POE adapter.
For what it’s worth when I measured the barrel connector in tool used to measure screw sizes it measured 2.78mm (7/64 in). I have no clue what the inner diameter is though.
Any help would be greatly appreciated.
