Zum Hauptinhalt wechseln
Was du brauchst
Dieser Teardown ist keine Reparaturanleitung. Um dein Camera zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. GooGo Teardown, GooGo Teardown: Schritt 1, Bild 1 von 2 GooGo Teardown, GooGo Teardown: Schritt 1, Bild 2 von 2
    • Opening the device by simply separating the two halves with a plastic prying tool.
Angehängte Dokumente
jerome cintas
179 Reputation
1 Anleitung geschrieben
7 Kommentare
I cant see where the camera is, is it a lense focusing onto a ccd on the motherboard???
Steve Rock - Antwort
Hi Jerome,
There is a small brass thread on the side of the Googo Camera,
Do you know what it is for.
many Thanks Dave Gould dave.gould@ymail.com
David Gould - Antwort
hi .. if there a place to solder in a more powerful antenna, would that even help?
sadstory - Antwort
Do you know how to reset the password of the camera by hardware?
Hugo Uchida Frausto - Antwort
My phone is showing error in camera can't be opened
Sib Gat - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 13
Letzte 30 Tage: 56
Insgesamt: 8,113
