Zum Hauptinhalt wechseln
Was du brauchst
Dieser Teardown ist keine Reparaturanleitung. Um dein Adapter zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. Nokia AC-16U USB Power Adapter Teardown, Crack Open The Case: Schritt 1, Bild 1 von 3 Nokia AC-16U USB Power Adapter Teardown, Crack Open The Case: Schritt 1, Bild 2 von 3 Nokia AC-16U USB Power Adapter Teardown, Crack Open The Case: Schritt 1, Bild 3 von 3
    • This power supply is slim and unusually attractive.
    • That white case is 39mm in diameter, and 15mm thick: pretty small for this power level (see heat sinks later).
    • The case is glued together, so you're not going to get into this one cleanly. I sawed a slot in the side, and used a screwdriver to crack the glue.
  2. Nokia AC-16U USB Power Adapter Teardown, What's Inside?: Schritt 2, Bild 1 von 3 Nokia AC-16U USB Power Adapter Teardown, What's Inside?: Schritt 2, Bild 2 von 3 Nokia AC-16U USB Power Adapter Teardown, What's Inside?: Schritt 2, Bild 3 von 3
    • The wall power pins lead to two spring contacts.
    • There's a plastic barrier between the low voltage and high voltage sides (you can't get much better than that!).
  3. Nokia AC-16U USB Power Adapter Teardown, How about some detailed PCB Photos?: Schritt 3, Bild 1 von 2 Nokia AC-16U USB Power Adapter Teardown, How about some detailed PCB Photos?: Schritt 3, Bild 2 von 2
    • Pretty tight layout.
    • Note the heat sink with thermal interface material, and the landing pads for the line voltage springs.
Bryce Nesbitt
1.023 Reputation
9 Anleitungen geschrieben
Ein Kommentar
Nice teardown
Omeke - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 20
Insgesamt: 2,563
