Zum Hauptinhalt wechseln
Was du brauchst
Dieser Teardown ist keine Reparaturanleitung. Um dein iControl Networks Piper zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. iControl Networks Piper Teardown, Cracking Open The Case: Schritt 1, Bild 1 von 1
    • Piper is held together with four "security Philips" screws located in the battery case. Each screw has a post in the middle, meant to foil use of a standard screwdriver. However....
    • If you don't have the right bit, just use a large #2 philips head screwdriver: the bit won't go deep enough to get tangled up in the security feature.
    • Once the screws are out use a plastic spludger to pry open four plastic clips holding the shell together.
  2. iControl Networks Piper Teardown, What's Inside: Schritt 2, Bild 1 von 3 iControl Networks Piper Teardown, What's Inside: Schritt 2, Bild 2 von 3 iControl Networks Piper Teardown, What's Inside: Schritt 2, Bild 3 von 3
    • Piper is dominated by a large speaker, and a Mallory PS-953Q security horn. It's loud. The CPU is a Texas Instruments TMS320DM365 media processor with a ZW0301 based Z-Wave module.
    • Piper uses two tiny antennas, one for Z-Wave one for WiFi.
    • That's it... a pretty simple layout.
Bryce Nesbitt
1.023 Reputation
9 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 12
Insgesamt: 2,178
