Von Studierenden verfasstes Wiki
Ein tolles Team von Studierenden aus unserem Bildungsprogramm hat dieses Wiki erstellt.
Camera will not turn on
Battery is dead
If the camera is not turning on, you can put it on the charging station to see if the battery is fully charged. The battery can be charged through a PC or an outlet.
Battery charger does not work
To test your battery charger, insert the charger into the right-side port of the camera labeled “charge.” If the camera is charging, a red light will appear on the side of the LCD screen. A flashing red light means you are charging in temperatures that aren’t ambient (between 50-86 F). If no light appears and the camera is still not turning on, the charging cord may be damaged. Try to obtain a new charging cord.
Battery is not completely in or battery cover open
If the camera is not turning on it could be that the card/battery door is open or the battery is not fully locked in. If this is true, insert the battery all the way in and lock the card/battery door.
Battery could have dirty exterior
If your camera is still not powering on after fully charging, the battery may be dirty. If this is the case, use a Q-tip and a drop of ethanol or rubbing alcohol, and clean the contacts of the battery (where the battery will connect to the camera). Then proceed to reinsert the battery and try turning the camera on.
Battery not in
If the camera is not turning on it could be that the battery is not in. Check the card/battery door to see if your battery is in its correct compartment.
Motherboard faulty
If all of the solutions above are unsuccessful, your camera’s motherboard may be faulty or died. To replace the motherboard, follow our replacement guide here.
Lens will not retract
Debris is in or around the lens
If you turn off your camera and the lens attempts to close, but fails to, dirt or sand may be in the lens. In order to remove the debris, use a can of compressed air to blow it away or a small brush to wipe it. Be careful not to let the dirt go near the lens in the front, as it may scratch it. Try to turn your camera off again. If the lens still does not retract, try to slip pieces of paper between components in the lens. Be careful not to tear the paper when doing this.
Camera needs to be reset
If you do not believe that debris is in the lens, you may just need to reset the camera. To do this, turn off your camera, remove the battery and let the camera sit for 30 seconds. Place the battery back into the camera and turn it back on.
Lens assembly is broken
If nothing else seems to be wrong, the lens assembly may be broken. The assembly should then be removed and replaced. The guide for this replacement can be found here.
LCD screen will not turn on
LCD screen is damaged
If your LCD screen is no longer showing images that you are taken or previously taken images and videos, your screen may be damaged. To replace your LCD Screen, follow our guide here.
If the LCD screen is not turning on, you may just need to reset the camera. To do this, turn off your camera, remove the battery and let the camera sit for 30 seconds. Place the battery back into the camera and turn it back on.
Camera sensor damaged
If your LCD screen is black when trying to take pictures or videos, but you are able to view previously taken pictures or videos, your camera sensor may be damaged. Click here to follow our guide on replacing your camera sensor.
Camera won’t take any more pictures
Memory card is full
On the LCD screen, a window should appear if your memory card is full. If this window pops up then you need to put in a new memory card.
Memory card not in
If the camera is not taking pictures, a window will pop up saying that there is no memory card in the camera. If this window pops up, you need to insert a memory card.
Lens will not extend
If nothing else seems to be wrong, the lens assembly may be broken. The assembly should then be removed and replaced. The guide for replacing this can be found here.
If you turn on your camera and the lens attempts to open, but fails to, dirt or sand may be in the lens. In order to remove the debris, use a can of compressed air to blow it away or a small brush to wipe it. Be careful not to let the dirt go near the lens in the front, as it may scratch it.
Ein Kommentar
how to reset language…..its currently in an Asian script..i want it in English..don’t know where to start
craig Tillman - Antwort
