Von Studierenden verfasstes Wiki
Ein tolles Team von Studierenden aus unserem Bildungsprogramm hat dieses Wiki erstellt.
Phone wont turn on
The Samsung Galaxy Alpha will not turn on.
Battery is not charged
Make sure that the battery is fully charged and installed correctly.
Water Damage
Take the battery out of the phone. Check the the oblong pad on the side of the battery that has the connections on it. If the indicator strip is white, the phone has not taken water damage. If the indicator strip is pink the phone has taken water damage and will likely not turn on because it is damaged.
Motherboard is bad
If the phone still will not turn on, the motherboard is likely bad. If this is true the motherboard will need to be replaced.
Phone has poor reception
The phone does not have enough of a connection to the wireless network.
In a location that does not allow mobile connection
If the Samsung Galaxy Alpha says no service on the screen, move to a new location and test the signal quality there. If you are in a building try moving outside to make sure your signal is unobstructed.
Bad Antenna
If your signal quality is consistently poor regardless of your location, your antenna might not have a good connection to the motherboard or it might be defective.
Motherboard is bad
If your phone still does not turn on, your motherboard is likely bad. You will need to replace the motherboard.
Phone is frozen
The phone's screen is unresponsive despite active usage
RAM is full
There are likely too many open applications, which can cause the RAM to be full.Ensure to close unused applications and programs. Another solution would be to temporarily minimize the usage of the phone. If this does not fix the issue restart the phone by holding down the power button.
Bad video driver
The best solution to correct the bad video driver is to reinstall a new one from the phone manufacturer’s website. After installation, test the new updated drivers and make sure the phone functions properly.
Motherboard is defective
If your phone is still frozen , the motherboard is likely defective. It would need to be replaced it with a new one from the manufacturer.
Phone is overly hot
The phones temperature is uncomfortably warm to the touch
Battery is defective
If the battery is defective it can easily cause the phone to become hot to the touch. If this is the case then the defective battery will need to be replaced with a new battery.
Battery is overcharged
If the phone has become overcharged it can become hot to the touch. Unplug the charge cable from the phone and hold down the power button till the phone turns off. If the phone is already powered off ignore the previous step. Then let the phone sit for at least five minutes before turning it back on.
Heavy application usage
When the phone is being used consistently for an extended period of time it may become hot to the touch. One option would be to tap the power button to shut the screen off and let the phone sit for at least five minutes to let the phone cool down. If the phone is very hot to the touch, hold down the power button and let the phone sit for at least five minutes before turning it back on.
Battery loses charge quickly
The usage time between charges is abnormally low
Unwanted application usage
Unused applications running in the background is the most common cause of decreased battery life. To solve this issue disable unwanted applications in the application manager to extend the battery life of the phone.
Battery defective
If the battery is defective usage time between charges will likely be very low. To fix this issue the battery will need to be replaced. Please follow the link below to find out ways to keep your phone's battery going strong.
50 Kommentare
Want to know why I haven't heard any sound of any kind from this phone
CATHY COOK - Antwort
My phone has no sound on videos everywhere else but vidios
annking4236 -
why no sounds
Dorothy Davis -
No sound on video or touch
hdmlt259 - Antwort
I have no volume what so ever
Debby Marx -
