Von Studierenden verfasstes Wiki
Ein tolles Team von Studierenden aus unserem Bildungsprogramm hat dieses Wiki erstellt.
Laptop Won't Turn On
Battery is Dead
Verify that the battery is securely attached to the laptop and then try turning it on. If it still does not turn on, plug in the power adapter. If it still does not turn on, try taking the battery out and turning on your laptop with just the power adapter plugged in. If this works, your battery is dead. Follow this guide to install a new battery.
Laptop Screen Is Cracked and Won't Display
If the lights illuminate upon powering on your device, but your laptop screen is cracked and/ or will not display, follow this guide to replace it.
Motherboard has Failed
If you tried all of the above techniques to power on your laptop and it still won't turn on, then the laptop's motherboard has failed. To install a new motherboard, follow this guide.
Laptop Overheats Easily
Your laptop gets really hot even when it hasn't been on for a long time. Make sure the laptop is on a flat surface and the vent is unblocked
Ventilation Grid is Dirty
On the bottom of the laptop you will find a circular ventilation grid. Try using compressed canned air to clear this grid out and remove any excess materials that may be obstructing the airway.
Fan Malfunction
If the laptop fan runs really loud or you don't hear it run at all, then the overheating is likely caused by a broken fan. Install a new fan by following this guide.
CD/DVD is Not Working
Any CD or DVD you place in your drive won't play, or isn't being read by your laptop.
Drive Needs to be Reinstalled
In the Windows Control Panel, select the Device Manager. Right click "DVD/CD-ROM Drives" and uninstall it. Reboot your computer and it will be reinstalled. If this does not work, the CD drive may need to be replaced. Follow this guide to replace the drive.
Internet Won't Connect
Your laptop isn't able to connect to the internet through WiFi or ethernet. Make sure all the setting in your web browser are correct. If the issue is not the browser, then it could be a hardware problem.
WiFi
Make sure that the WiFi device is enabled. In the Windows Device Manager, right click on the WiFi device in and disable it. After it is disabled, enable it again. If the WiFi card is enabled and it still can't connect, then the WiFi card needs to be replaced.
Ethernet
Like the WiFi card, make sure that the ethernet device is enabled in Windows Device Manager. If it is enabled and it still can't connect, then check to make sure that the pins in the ethernet port are not bent. It then pins are bent use a small screwdriver to bend them into place.
Not Enough Memory
There is a limited amount of memory on every computer. Once the limit is reached, your computer’s performance can decline dramatically and no more new files can be stored.
External Hard Drive
You can purchase an external hard drive to keep your files outside of your computer. Doing so can free up some of the memory in your computer and increase its performance.
Upgrading Internal Hard Drive
If you do not want to keep you files anywhere outside of your computer, you may consider upgrading your hard drive. Keep in mind that you have to back up all your files outside of your laptop before doing so, or else the files may be lost.
Keyboard Not Working
If your keyboard is not responding, there are a few possibilities that may cause it to malfunction.
Jammed Keys
Use a brush to swipe across the keyboard to get all the dust out. You can also purchase a can of compressed air to remove dust and other particles from the keyboard.
Driver Errors
In the Windows Control Panel, select the Device Manager. Right click "Keyboard" and uninstall it. Reboot your computer, and it will be reinstalled.
Broken Keyboard
If none of the above works, your keyboard may be broken. Follow this guide to replace it.
2 Kommentare
Webcam not working
ceoh197171 - Antwort
Is there something I can download to make it work.
