Zum Hauptinhalt wechseln
Was du brauchst
Dieser Teardown ist keine Reparaturanleitung. Um dein iMuto 20000mAh Portable Charger zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. iMuto 20000mAh Portable Charger Teardown, The iMuto 20,000mAh Portable Charger: Schritt 1, Bild 1 von 2 iMuto 20000mAh Portable Charger Teardown, The iMuto 20,000mAh Portable Charger: Schritt 1, Bild 2 von 2
    • The iMuto 20,000mAh Portable Charger
  2. iMuto 20000mAh Portable Charger Teardown, Chop Chop!: Schritt 2, Bild 1 von 1
    • Using micro screwdrivers, needle-nose pliers, and a diagonal cutter... Leverage and pry the plastic band until you can chop it with the diagonal cutters.
  3. iMuto 20000mAh Portable Charger Teardown, Pry off the case top with a screwdriver.: Schritt 3, Bild 1 von 1
    • Using a screwdriver, wedge between the plastic band and the case top, then use a twisting motion in the direction like you would driving a screw to work your way around the case, prying the case top from the middle band of plastic.
  4. iMuto 20000mAh Portable Charger Teardown, This Charger Isn't Meant For Disassembly.: Schritt 4, Bild 1 von 1
    • Once you ungracefully chop and pry the case off of the charger, you can see why it is not meant to be disassembled or repaired. The case has clips that hold the case together and these clips can't be easily unclipped.
  5. iMuto 20000mAh Portable Charger Teardown, Lots of glue...: Schritt 5, Bild 1 von 1
    • If you have difficulty prying the case off, it's because of all the glue holding it together... Pry harder!
  6. iMuto 20000mAh Portable Charger Teardown, Main Circuit Board: Schritt 6, Bild 1 von 1
    • Here's a look at the main circuit board. The micro USB charging port is hidden at left, the two main USB ports are in front on either side of the light, and the number display is hidden at the bottom.
  7. iMuto 20000mAh Portable Charger Teardown, Battery Board: Schritt 7, Bild 1 von 1
    • There is a smaller circuit board, presumably for voltage regulation, that connects to the battery bank and then, via red and black wires, to the main circuit board.
  8. iMuto 20000mAh Portable Charger Teardown, Number Display: Schritt 8, Bild 1 von 1
    • Here's the LED number display. Note that I've briefly pushed the small button on the right side and the display shows zero charge.
  9. iMuto 20000mAh Portable Charger Teardown, The Culprit: Schritt 9, Bild 1 von 1
    • This is why I was unable to charge the iMuto charger... The small five-contact metal connector (on my finger tip) that is internal to the micro USB port (on the left side of the main circuit board, just above my finger tip) had broken off and fell inside the iMuto charger.
  10. iMuto 20000mAh Portable Charger Teardown, Conclusion, For Now.: Schritt 10, Bild 1 von 1
    • This could be repaired by soldering a new micro USB connector port to the main circuit board, but it won't look pretty after reassembly!
Polack
101 Reputation
1 Anleitung geschrieben
Ein Kommentar
After checking my IMUTO power bank it appear a component on the battery board is burnt. What can I do ?
tosyne001a - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 10
Letzte 30 Tage: 56
Insgesamt: 7,206
