Zum Hauptinhalt wechseln
HP Pavilion 17-f127ds Optical Drive Replacement
Was du brauchst
  1. HP Pavilion 17-f127ds Optical Drive Replacement, Battery: Schritt 1, Bild 1 von 3 HP Pavilion 17-f127ds Optical Drive Replacement, Battery: Schritt 1, Bild 2 von 3 HP Pavilion 17-f127ds Optical Drive Replacement, Battery: Schritt 1, Bild 3 von 3
    • Before starting, please turn off your laptop.
    • Slide the battery lock latch, the latch on the left, inwards.
    • Slide the battery release latch on the right inwards to release the battery.
    • The latch may require significant force to slide.
    • Lift the battery up and remove it from computer.
  2. HP Pavilion 17-f127ds Optical Drive Replacement, Optical Drive: Schritt 2, Bild 1 von 2 HP Pavilion 17-f127ds Optical Drive Replacement, Optical Drive: Schritt 2, Bild 2 von 2
    • Use a Phillips #1 screwdriver to remove the screw holding the Optical Drive in place. It is located near the center and vents of the laptop.
    • Use a spudger to help unseat the drive. Pull the drive out from the laptop.
  3. HP Pavilion 17-f127ds Optical Drive Replacement: Schritt 3, Bild 1 von 1
    • If you need to replace the bracket on the Optical drive, remove the two Phillips #0 screws holding the bracket in place. The bracket can be placed on the new drive.
Abschluss
Stephen Brown
201 Reputation
2 Anleitungen geschrieben
UW Tacoma, Team S3-G1, Liner Fall 2017 Mitglied von UW Tacoma, Team S3-G1, Liner Fall 2017
UWT-LINER-F17S3G1
5 Mitglieder
4 Anleitungen geschrieben
Ein Kommentar
I can’t remove the HP Pavilion 17-x016ds Optical Drive. NEED HELP. Is it necessary to remove it in order to remove bottom panel to replace HDD with SSD? Also can’t remove bottom panel.
Nick Koriakin - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 13
Insgesamt: 911
