Einleitung
If you need to replace any of the internal components of your laptop, you will first have to remove the HDD/RAM cover panel to gain access. This guide will show you the necessary steps needed to accomplish this.
Was du brauchst
Use a Phillips #000 screwdriver to remove the two 9mm screws from the HDD/RAM cover panel.
Slide the back panel off by placing a hand on each corner and pulling the panel towards you.
Fast fertig!
Abschluss
