Zum Hauptinhalt wechseln
360fly 4K Battery Replacement
Was du brauchst
  1. 360fly 4K Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Flip the camera upside down and peel off the two plastic screw covers with the metal spudger to reveal the screws.
  2. 360fly 4K Battery Replacement: Schritt 2, Bild 1 von 1
    • Remove the two 5 mm screws from the bottom of the camera with a T4 screwdriver.
  3. 360fly 4K Battery Replacement: Schritt 3, Bild 1 von 2 360fly 4K Battery Replacement: Schritt 3, Bild 2 von 2
    • Gently pry the plastic ring from around the charging plate with the metal spudger.
    • Remove the outside shell by pressing against the center of the charging plate and pulling the bottom shell away from the top shell.
  4. 360fly 4K Battery Replacement: Schritt 4, Bild 1 von 1
    • Remove the five 2 mm screws using a T4 screwdriver.
    • Pull off the charging plate assembly.
  5. 360fly 4K Battery Replacement: Schritt 5, Bild 1 von 2 360fly 4K Battery Replacement: Schritt 5, Bild 2 von 2
    • Gently pry the plug off the port on the circuit board with a plastic opening tool.
    • Remove the four 2 mm screws using a T4 screwdriver.
    • Remove the circuit board from the device.
  6. 360fly 4K Battery Replacement: Schritt 6, Bild 1 von 3 360fly 4K Battery Replacement: Schritt 6, Bild 2 von 3 360fly 4K Battery Replacement: Schritt 6, Bild 3 von 3
    • Remove the five 4 mm screws around the battery assembly with a T4 screwdriver.
    • Lift the battery assembly and gently pry the plug out of its port on the board below with a plastic opening tool.
    • Press the battery from the back of the battery assembly to remove it with a plastic opening tool until the glue releases the battery.
    • Potential for device damage: Do not puncture or bend the battery. Use a small amount of heat to assist in softening the adhesive if necessary.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Jacob Herron
463 Reputation
3 Anleitungen geschrieben
IUPUI, Team S5-G3, Baechle Fall 2017 Mitglied von IUPUI, Team S5-G3, Baechle Fall 2017
IUPUI-BAECHLE-F17S5G3
3 Mitglieder
4 Kommentare
Wich one battery Can I use to replace It?
Marco Pereira - Antwort
Where can i purchase a battery
john hernandez - Antwort
I would like to purchase a 360 fly battery
Where can I buy the battery?
Mark - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 17
Letzte 30 Tage: 46
Insgesamt: 2,468
