Einleitung
The battery supplies power to the laptop. The battery may need to be replaced if the laptop is a few years old, as batteries will start to lose their life after being used for a few years.
Was du brauchst
Remove the following eighteen screws using a Phillips #0 screwdriver.
Using a Phillips #0 screwdriver, unscrew the screw on right side of the battery placement.
Using a plastic opening tool, disconnect the wires connecting the battery to the motherboard.
To reassemble your device, follow these guidelines in reverse order.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
