Zum Hauptinhalt wechseln
Sonos Bridge Power Port Replacement
Was du brauchst
  1. Sonos Bridge Power Port Replacement, Power Port: Schritt 1, Bild 1 von 1
    • The rubber bottom is glued on, meaning it can be easily pried off using the metal spudger.
    • You may have to pry from multiple locations.
  2. Sonos Bridge Power Port Replacement: Schritt 2, Bild 1 von 3 Sonos Bridge Power Port Replacement: Schritt 2, Bild 2 von 3 Sonos Bridge Power Port Replacement: Schritt 2, Bild 3 von 3
    • There is one screw in each corner of the base for a total of four screws.
    • Remove each screw using the Phillips 1 screwdriver.
    • The four screws are each 0.9 cm long.
    • The screws are small, so be careful to not lose them.
  3. Sonos Bridge Power Port Replacement: Schritt 3, Bild 1 von 2 Sonos Bridge Power Port Replacement: Schritt 3, Bild 2 von 2
    • Use the metal spudger to pry out the plastic bottom.
    • Alternatively, the casing can be lightly tapped on a table (base down) to drop the bottom out of the casing.
  4. Sonos Bridge Power Port Replacement: Schritt 4, Bild 1 von 2 Sonos Bridge Power Port Replacement: Schritt 4, Bild 2 von 2
    • Pry out the circuit board.
    • Place the metal spudger under the board on the side opposite the two ports.
    • The board can then be easily wiggled out of the casing.
    • This should NOT require significant force.
  5. Sonos Bridge Power Port Replacement: Schritt 5, Bild 1 von 2 Sonos Bridge Power Port Replacement: Schritt 5, Bild 2 von 2
    • Locate the Power port on the circuit board, shown with the red box in the first image.
    • Locate the solders attached to the Power port.
    • Use the soldering iron to undo the solders.
Abschluss
Brian Strader
201 Reputation
2 Anleitungen geschrieben
IUPUI, Team S3-G4, Harley Fall 2017 Mitglied von IUPUI, Team S3-G4, Harley Fall 2017
IUPUI-HARLEY-F17S3G4
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 13
Insgesamt: 1,188
