Zum Hauptinhalt wechseln
Acer Chromebook CB5-571-C5XU Fan Replacement
Was du brauchst
  1. Acer Chromebook CB5-571-C5XU Fan Replacement, Bottom Case: Schritt 1, Bild 1 von 2 Acer Chromebook CB5-571-C5XU Fan Replacement, Bottom Case: Schritt 1, Bild 2 von 2
    • Remove the following eighteen screws using a Phillips #0 screwdriver.
    • Make sure the Chromebook is unplugged and shut down, so no files are lost and there is no risk of electrocution.
  2. Acer Chromebook CB5-571-C5XU Fan Replacement: Schritt 2, Bild 1 von 2 Acer Chromebook CB5-571-C5XU Fan Replacement: Schritt 2, Bild 2 von 2
    • Using the flat side of the spudger, pry open the bottom case of the laptop.
    • Working from the front to the back, where it connects to the screen, proved to be the easiest way of popping the case off.
  3. Acer Chromebook CB5-571-C5XU Fan Replacement, Fan: Schritt 3, Bild 1 von 2 Acer Chromebook CB5-571-C5XU Fan Replacement, Fan: Schritt 3, Bild 2 von 2
    • Using a Phillips #0 screwdriver, unscrew the screw to the right of the fan.
    • Remember to have a small container to place the screw in, so it does not get lost.
  4. Acer Chromebook CB5-571-C5XU Fan Replacement: Schritt 4, Bild 1 von 2 Acer Chromebook CB5-571-C5XU Fan Replacement: Schritt 4, Bild 2 von 2
    • Using the Phillips #0 screwdriver, unscrew the four screws connecting the heatsink to the motherboard.
    • Remember to have a safe place to place the screws, so none of them get lost.
  5. Acer Chromebook CB5-571-C5XU Fan Replacement: Schritt 5, Bild 1 von 3 Acer Chromebook CB5-571-C5XU Fan Replacement: Schritt 5, Bild 2 von 3 Acer Chromebook CB5-571-C5XU Fan Replacement: Schritt 5, Bild 3 von 3
    • Carefully unhook the black and white wires from the circumference of the fan.
    • It might help to use the pointed end of the spudger tool to unhook the wires.
    • Do not tug too hard on the wires, as they can easily disconnect and snap off from the motherboard.
  6. Acer Chromebook CB5-571-C5XU Fan Replacement: Schritt 6, Bild 1 von 2 Acer Chromebook CB5-571-C5XU Fan Replacement: Schritt 6, Bild 2 von 2
    • Using the spudger tool, carefully remove the wires connecting the fan to the motherboard.
  7. Acer Chromebook CB5-571-C5XU Fan Replacement: Schritt 7, Bild 1 von 2 Acer Chromebook CB5-571-C5XU Fan Replacement: Schritt 7, Bild 2 von 2
    • Using the flat side of the spudger, firmly pry the fan off of the components, as well as the heatsink from the motherboard.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Erin Moffatt
282 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team S6-G1, Rockett Fall 2017 Mitglied von UMass Dartmouth, Team S6-G1, Rockett Fall 2017
UMASSD-ROCKETT-F17S6G1
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 274
