Zum Hauptinhalt wechseln
HP Pavilion 17-f127ds Speakers Replacement
Was du brauchst
  1. HP Pavilion 17-f127ds Speakers Replacement, Battery: Schritt 1, Bild 1 von 3 HP Pavilion 17-f127ds Speakers Replacement, Battery: Schritt 1, Bild 2 von 3 HP Pavilion 17-f127ds Speakers Replacement, Battery: Schritt 1, Bild 3 von 3
    • Before starting, please turn off your laptop.
    • Slide the battery lock latch, the latch on the left, inwards.
    • Slide the battery release latch on the right inwards to release the battery.
    • The latch may require significant force to slide.
    • Lift the battery up and remove it from computer.
  2. HP Pavilion 17-f127ds Speakers Replacement, Keyboard: Schritt 2, Bild 1 von 2 HP Pavilion 17-f127ds Speakers Replacement, Keyboard: Schritt 2, Bild 2 von 2
    • Flip your laptop over on a firm surface.
    • Using a Phillips #1 screwdriver, remove the thirteen screws on the back of your laptop.
    • Flip your laptop back over.
  3. HP Pavilion 17-f127ds Speakers Replacement: Schritt 3, Bild 1 von 3 HP Pavilion 17-f127ds Speakers Replacement: Schritt 3, Bild 2 von 3 HP Pavilion 17-f127ds Speakers Replacement: Schritt 3, Bild 3 von 3
    • Using the opening tools, separate the keyboard from the laptop by prying it from the base along the sides of the laptop.
    • With your fingers, disconnect the keyboard connector and the connector cable from the motherboard.
    • Be careful not to lift the keyboard too high because it might rip off the connectors.
    • Carefully remove the keyboard.
  4. HP Pavilion 17-f127ds Speakers Replacement, Speakers: Schritt 4, Bild 1 von 2 HP Pavilion 17-f127ds Speakers Replacement, Speakers: Schritt 4, Bild 2 von 2
    • Disconnect the tape connecting the WLAN module to the main board.
    • With a Phillips #0 screwdriver remove the remaining screw holding the speaker in place.
  5. HP Pavilion 17-f127ds Speakers Replacement: Schritt 5, Bild 1 von 2 HP Pavilion 17-f127ds Speakers Replacement: Schritt 5, Bild 2 von 2
    • Disconnect the speakers from the main board.
    • Lift away the speakers, they are connected with a wire.
Abschluss
Stephen Brown
201 Reputation
2 Anleitungen geschrieben
UW Tacoma, Team S3-G1, Liner Fall 2017 Mitglied von UW Tacoma, Team S3-G1, Liner Fall 2017
UWT-LINER-F17S3G1
5 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 4
Insgesamt: 354
